Dear OcUK Friends...
I may have accidentally got a bit carried away with eBay this evening and happened to bag myself a AMD HD 7990 - I won't tell you the price, it will make your eyes water.
However, it gets worse. Today I also bought 3 x R9 290 cards and a 1000W Silverstone PSU.
My next question is - will me shiny new PSU be enough to power these four cards? If you haven't guessed already, I'll be mining with them so all the other componenets are very low specification.
Thanks in advance!
Thanks in advance!
. The 3 290 will use 870w and the 7990 is 375w thats over 1240w of gpu. You need one of those superflower psu's that 8 pack was using. Even then you will also need some detla fans to remove all that heat from your case.
I think thats the problem.
