 - 10 May 2012
http://www.amd.com/pl/products/desktop/graphics/7000/7970/Pages/radeon-7970.aspx#3
amd hd 7970 925mhz 1375mhz
I will check that now mate.
I red that ghz bios operates on lower voltage and gives higher clocks
Sill now luck
I tick allow voltage control,and still can't do it.
I gain extend official oc limits,before I could only set 1125 maks. and 1575.
Am I doing something wrong or this card is voltage locked,and the only way to unlocked it, is to flash bios?
	Where is the best place to download Trixxx?(without other crappy programs along the way?)How bizarre. You can leave unofficial overclocking mode disabled btw. Don't know if that will make any difference. At this stage all i can suggest is to try Trixxx instead.
Will do in the evening,now I got other stuff to do.
Cheers for your help Matt
Already downloaded Trixxx,and IT'S WORKING!
Yeah it's a pity.
I'm totally new to Trixx,can I display temps,clocks,during gaming(left to corner) or I need download other program to monitor that?
Trixxx only control core voltage?,what about memory voltage?
So trixxx and msi afertburner working alongside together,won't cos any interference?
My values in trixxx for vddc 1,2V - gpu-z=1,156V
1,212V - 1,184V
Is that normal? As far as I now 1,25V is safe for this card,but I won't achieve this voltage cos trixx got maks. vddc to 1,3V but gpu-z readings are much smaller?
What is the best stability test for OC?
I'm running sleeping dogs on highest possible setting (1920x1200)?
