- 11 Apr 2006
- Earth
It won't let me in to Recovery Mode. Won't boot in to Android. Bricked it
Grrrrr
Still cannot update this phone to 4.4.2
It tells me there's a system update ready to install. It reboots the phone and it goes in to TWRP recovery to run the install. Then fails but no idea why.
Do I need to unroot? Hope I don't have to flash it back to stock. Fed up of reinstalling all my apps all the time.
All the paid for version gives you is the ability to automatically update various files etc otherwise you have to download them yourselfI used to use that one, before it was skipsoft, I had a previous install, it updated this morning to skipsoft version and although I made a donation to the original one, it now says I can't use it properly because it's not the paid/donated version. Annoying.
I've acquired a laptop from work now and currently downloading images etc. Hoping I can get it sorted.
I'll use XDA if I need to later and I haven't pulled all my hair out.
I paid for it to save me hunting roms etc
Can you get into fastboot (not recovery) on the phone?
Use this guide but ignore the custom recovery bit. If you can get the phone into fastboot (volume + and - held while holding down power to turn on phone). You should be fine to use fastboot to flash stock recovery, bootloader and rom
http://www.cultofandroid.com/23782/rooting-the-google-nexus-4-the-right-way-how-to/
