Thanks for the tips, guys.
I've seen a video on recoiling and rewicking. I'll be getting into that soon, looks pretty easy and cheaper. Vape Mesh company the best place? I'll ask here again at a later stage for help on wick type, gauge, wire type and gauge.
Yeah, I'm changing flavour groups. I've got loads of Isopropyl, that be ok for soaking the flavour wick before reusing the wick? Yes, I want a Pyrex glass tank, but I'd also like it to have a removable dripper or at least where I can do dripping if I need to. Which would be a good machine for that?
It depends on how important it is not to taste the previous flavour - if you're just switching to a similar type or theme e.g Raspberry to Strawberry, Custard to Creme Brulee, Menthol to another Menthol... Either just refill and enjoy the brief combo (I discovered Apple Tart and Accie's Ambrosia makes a fantastic mix this way)...
Or if you want minimal effort Then just a flush through with hot water and take the opportunity to dry-burn the crud off the coil.
If you're switching from flavour group to another e.g. Menthol to Custard - then I'd be cleaning and soaking the lot - Isopropyl Wipes, dry burn or even take the time to recoil, and don't forget to lose the flavour wick (or at least reduce it).
And YES, Bananana (other fruit/citrus flavours do too!) can crack plastic/polycarbonate. So buy Pyrex tanks in future, for not much more. Or upgrade and check out the Davide-S with Aspire BDC Glassomizer or the latest (fugly) Aspire BDC version Todd's just reviewed (should be on YT shortly)...
