Permabanned
- 9 Dec 2010
Anyone gone from a 7970 to the 290X here?
Yea from what I've seen the GTX780Ti generally got higher max frame rate than the 290x, but minimum and average there's not much difference.Yes and IMHO the difference is tremendous. For a start the card trade blows with a Titan and bosses the 780, the 780TI is a differenrt story but there isnt that much in it.
Aside form the Black Screen issues (when over clocking for me) the card is amazing and I love mine. I was about to sell mine and buy 780TI but have since decided not too.
Still getting the blackscreen crashes on bf4, definitely memory related and seems even worse with the 9.4 drivers.
Anything over 1400mhz on the memory and I get blackscreen crashes at random times
Wish it would give you some warning in the shape of artifacts beforehand though.
Hopefully as the drivers mature the problem will get fixed.
Just to clarify, this only happens when overclocking the memory, imo it's a driver issue and not a fault with the card.
9.2 was fine and I could bench at 1625.
No selling outside the members market I'm afraid. Did you not get one with your GPU?
Would you guys say that running at 1.3v on Asus GPU Tweak fine for 24/7 gaming?
Peaks around 1.25 volts at 1200/1450. Max temp 52 under water.
Im not sure what volts are fine for gaming on GPU's (New to GPU OC'in)
Even if it was to hit 1.3 during gaming would that be ok?
I've bought myself a waterblock for mine, looking forward to see what it can do with the extra cooling as I haven't tried overclocking it yet.
I have managed to get a stable overclock (BF4 no artifacts/Crashing) of 1220/5300, any higher on the memory and I get black screen crashes, any higher on the core I get artifacts. I can run benchmarks (valley/heaven) at 1250/5700 no problems, but I'm quite happy with this overclock for BF4 at least. Maybe it'll change with driver updates and maybe with some BF4 patches/Mantle.
Guess we'll wait and see.
There is no mem voltage on Hawaii reference boards. Only way to get it is with a hard mod.
I saw some info about this here: http://kingpincooling.com/forum/showthread.php?t=2473&page=6
Either overclock is safe. Save each profile and activate them manually if you need the extra grunt. If i wasnt so sure that half my GPU tweaking software would rebel if i switched afterburner on auto start, iw ould have my 1233/1500 24/7.
Going to flash to Asus bios soon (prob wait for a mantle supported benchmark tool or for mantle to be patched into some mainstream games) and then really abuse the 540mm of radiator thats cooling one CPU and one GPU.
Received my 290X yesterday and what a beauty it is. A major upgrade from my 6870.
Add me to the owners roll of honour![]()
