Lol ok that's quite amusing, amusing in the fact that you actually left a little dot, why did you bother to leave the dot of light?
I like the little dot it matches all my other little dots now.![]()
The cables make me mad....![]()
I think mine would do MOOGLEYS head in
Just a warning Spook that that even Sony rec laying the console flat as theres a vent covered up now which is keeping hot air in the case
Sony didnt say anything of the sort AFAIK (still selling an officially licensed stand so I dont see how they arent recommending it), its more that if you do stand it up vertically the stand does block a vent, but the stand itself does have a channel to allow air to pass though its obviously not as big as the vent.
Some users have noticed the PS4 might be warmer standing up so that might be where the recommendation is from...
EDIT: Having it on carpet might not be the best idea - likely to trap any heat its pushing out from the bottom?
ps3ud0![]()
If you ever find that link Id be very interestedSony did or one of sonys mouthpeices did anyways. I remember one of the podcasts I listen to saying that but it was a while ago so I couldnt tell you who or when but they were laughing about the official stand as well. Plus to recommend you lay it flat is not saying do not stand it up at all,just its better to lay it flat. Youre right it does have the channel but its not as optimal as a clean exhaust from the side is it.
But the over-reaction has been on your part, consider yourself arrested!
And... cheer up it's christmas![]()
PS4 sucks air in from the sides and blows it out the back. The official stand has a vent built in to prevent blocking the intake.
Not heard Sony saying it should not be stood up only that it was designed so you could. MS said the Xbox one cannot be stood up could be the confusion ?
