quick question
can you run 4 drives, 1 SSD and optical drive at once or is it just 4 drives and either SSD or optical?
Does anyone here run any form of TV/PVR function off their microserver?
Looks like mediabrowser 3 (which I run off mine) is about to offer live TV functionality and I wondered if these little boxes were up to the job?
Cool, any link to the card and is it a dual tuner?I use XBMC with Next PVR coupled with a DVB-T2/DVB-S2 card,im just using it for freeview HD and it works well. I then have various Raspberry pis around the house running Rasbmc that can also pickup the channels from the server.
when i last looked it didn'tand to think i just updated to the stock hp one to get 8.1 one
quick question
You can. There are many posts of people with this and more. Space wise you can put the SSD in the ODD space with a slim line ODD, or you can use a full size ODD and put the SSD under it, behind the HP light.
As long as you see a hacked BIOS, you can connect the SSD to the Esata and the ODD to the supplied ODD connection.
I havent done this. I prefer to just use an external ODD when I need it, which isnt often.
exactly the way i wanted to do things, due to my dvd seemingly refusing to play ball, but finding slim dvd converters are hard to find out here... opted for a usb dvd instead only to find out that i threw away the dvd blanking cover, so had to leave the dvd in not to have a huge hole....
Anyone willing to send me their dvd balnking cover (n40l)?
Get a single hard drive hot swap caddy and whack another drive in there.
Thats what I did.
), had a good year out of that and then cloned it to a 64GB M4 SSD, never had any issues with it. So it'll be a pre-install check. Not really sure why it needs to be an issue, anyone using it for doing backups should surely use multiple HDDs anyway, so ive no idea what the reasoning behind a 160gb limit would have been.If I use the DVD bay in the future I'd like to put a few 2.5 inch drives in there...
