- 5 Sep 2011
- Surrey
Pays off sometimes buying at launch
Pays off sometimes buying at launch![]()
Only the one loop but with two huge MO-RA3 420 PRO - Black external rads. The first job though is to get the cards running on air together and then get the water blocks on them.
I'm still undecided on my full blown cooling for this setup and have a temporary one in place. What pump and reservoir are you using?
Quick disconnects on the res I see. I was going to put them on my GPU bridge but might just leave one as a drain and that's it. They're handy but clunky.
I have a 3930k, 3960X and a 3970X, the slowest is the 3970X which is good for 4.9ghz. When you compare these CPUs to their IB-E counterparts it is a bit of a non contest as what you lose on efficiency you more than make up for on higher overclocking headroom. With a multi GPU setup (3 or 4 cards) the one thing you need more than anything else is raw speed.
I have got a brand new 4930k CPU which I will try at some point but if it can not do at least 4.9ghz (not likely with IB-E) then it will only be good for benching one or two cards where efficiency is more important than raw speed.
You really should look at X79 or Haswell-E as it is not that much more expensive than what you have got now. If you were to go for a mainstream X79 mobo (you don't need everything a RIVE has) and a secondhand 3930k you could put together a very powerful system quite cheaply.
