If it's less white then there's going to be less visible light from the same power unit, no?
No.
As the colour temp increases beyond 4300k the usable output of light falls.
Found a couple that must have been taken not long after they were done plus one from this evening
[TW]Fox;25567977 said:No.
Ok well I dont want it to look chav but I also dont want it to look yellow as Im trying to get the car to look as fresh as possible given its nearly 10 years old now. 5000k sounds right.
	4300k doesn't look yellow at all really. 5000k may be closer to natural daylight (6500k) but where headlights are concerned the output has a blue tint to it from certain angles. 4300k doesn't.
4300k:
[TW]Fox;25569614 said:His are factory fit.
[TW]Fox;25569616 said:Mine are 4300k and it doesn't look yellow at all.
I am sometimes a bit blind but that cheaper set don't claim to be canbus compatible. You will therefore get errors from the car thinking the bulbs are out.No problem. So many kits around
These caught me eye but cant see why the one is nearly double the price.
http://www.ebay.co.uk/itm/120841709139?ssPageName=STRK:MEWAX:IT&_trksid=p3984.m1423.l2649
http://www.ebay.co.uk/itm/251119996224?ssPageName=STRK:MEWAX:IT&_trksid=p3984.m1423.l2649
What you guys think?
Finally treated my Z4 to some non-RFT. Massive ride and handling improvement, feels like a brand new car honestly.
