I just bought an LG G2 32GB, and it's got the software version D80210b-HKG-XX.
Is there any point in changing it to the EUR version?
How would you go about doing it? (it's my first android phone)
Thanks
I just tried to check for updates, but it says that i have got the latest software version for current OS. Is there any other way to check apart from the About Phone > Update Center > Software update ?
No other way. Is your G2 carrier branded or sim free?
You could always download the latest version and flash it on the phone using LG's flashing tool.
What charging dock is that and have you found out what that 740mb update was for yet?
I lost my G2 and got a Nexus 5 as its much cheaper but think I would like another G2.
As for the speaker it's slightly better than the N5.
No problems with the speaker on mine. Nor the rear buttons, really easy to use.
Mines been properly stable, reliable and a joy to use, very happy with it and glad I chose it over the competition![]()
