Whats good decent 16gb ram that work well in these?
@easyrider did you have to mod BIOS to get it to work or they just work straight out of the box? thanks!
Mine just arrived, but I want to upgrade to 16GB before starting to play with it
Leavig the stock bios is a mistake imo
You want to get that internal SATA port AHCI enabled and move the HDD into the DVD bay.
Allowing for 4 x Storage drives.![]()
I'm still running mine on the stock BIOS.
Nothing in the dvd hole, ssd as boot drive pair of 2tb wd reds and a 4th seagate coming tomorrow...
Also my N54L is still running on the 2Gb RAM it came with, which is below the minimum for ESXi so I'd have to buy more. A guy I know who also has an N54L has upgraded his RAM and offered to give me the 2Gb he took out for £10 or something, so I could do that - but I feel like 4Gb for VMs is probably still a bit low - What do you guys think? I was thinking I'd be better of just getting a 16Gb set if I'm serious about VMs.
Can anyone tell me if it's okay to mix 4TB drives in alongside existing 3TB drives on the N40L, using WHS 2011?
I've currently got four 3TB WD Reds filling up all the main bays, grouped using Stablebit DrivePool, and yet am still running out of room. I figure I can add a fifth drive up in the drive bay at the top, mounted above the stock drive used for the OS which came with the microserver.
I suppose I could then think about switching out that OS drive for an SSD one, and squeeze in a sixth storage drive.
After that, I suppose my only option is to replace the 3TB drives with 4TB ones (don't know what I do with the old 3TBs at that point), unless there's another way to expand storage.
Also, anyone know if the Nexus DoubleTwin HHD decoupling is in stock anywhere, or likely to be soon? Don't much fancy having to file down the fins on the Feser Silent Arrow in order for it to fit.
Desk
I used folded paper, made an 'n' type fold and used tape to hold it in place.
I have this issue quite a lot, i swear blue lights are the bane of my life, since falling in love with the rich blue LED on the PS2, its spread to pretty much everything to the point that a small room can be lit on computer LED's alone
I think most of my hatred stems from the fact that Bloomin everything has blue LEDs in them, CPU coolers, fans, fan controllers, mobos etc. If you dont want blue LED's your left either having to disable them or pick inferior products because the manufacturers plaster their product full of the evil little things! It carries through to things like mobos with blue components (heatsinks, sata ports, ram sockets, PCI-E ports etc).
The HP light could warn passing ships at night, and im in Manchester!![]()
I bought the Kingston KVR1333D3E9SK2/16G 16GB 1333MHz CL9 DDR3 ValueRAM ECC Memory Kit
I thought it was limited to 8GB, or so it says on HP's site![]()
it's working like a charm now...
