- 24 Apr 2011
Yeah that was my thoughts too... I dont really want to RMA this card as its unlocked to a 290x... Dont know if theres a replacement for it.
Think its largely down to immature drivers and a completely new power tune implementation. Seems like they're a few kinks in the system that need ironing out.
People have been reporting that RMA replacements have sorted the issue for them so why mess around waiting months for an unlikely fix? it's been 2mths already and AMD look to have already brushed it under the carpet.
When you're running hardware at such a high temperature all it takes is a single weak component to cause problems, that's why in every other industry temperatures are kept down to a minimum. Running at such a high temperature puts undue stress on hardware and is not good for reliability especially in the long term.
Not sure - I know 1-2 people who've RMA'd their 290(X) due to the blackscreen thing and the replacement has been fine, no changes to drivers or their system setup.
thought about rma'ing mine but i dont think its hardware as i can play single player ghosts for hours untill i get to the same part and blackscreens loading, if its hardware fault then im guessing it would blackscreen randomly plus if i send it back ocuk could test it for days without finding a fault and just charge me to send it back and be no better off, im begining to think i should have just stuck with the old 7970 crossfire
i have already played the game once with the 7970's without any problems apart from xfire not working so i just disabled xfire and played on one gpu
I just tried starting cod ghosts from an earlier save and all was well until it blackedscreened at the the exact same location, surley its got to be a software problem
GameWorks im afraid.![]()
yeah great, except it didn't work in SLI either, but go ahead and keep those blinkers on
yeah great, except it doesn't work in SLI either, but go ahead and keep those blinkers on
Yea, and I think the SLI performance is actually bottlenecked by the CPU:
670-58.6 avg
690-92.6 avg
~60% scaling?
In both those results, SLi scaling is working at about 60%, it's not optimal by a long shot, but a 60% increase is way way better than 0%.![]()
