Yesterday I learned all about the Peugeot's rear drums. I had not worked on rear drums before other than to adjust a handbrake. I decided to replace the handbrake cable and shoes to ensure it's refreshed.
Little did I know that whoever had fitted it previously had managed to make it fit the wrong way around and I was trying to replicate that, completely baffled at how they managed to stretch the springs behind the shoes. One Google picture search later and found how it should have been assembled. Much easier. Although I still hate shoe springs![]()
WHen i rebuilt the E36, one thing that is meant to be a pain is the rear drums and handbrake mech
I had never worked on a drum set up before hand (or hadnt refurbished one) but just got the parts diagrams out and it worked out pretty well and now ive got a full functinoal handbrake which is meant to be rare on E36s
Always amuses me how big and wide the rears look when off the car.
Installed Blackvue Dashcams
Been a very hectic weekend for me so I haven't had chance to view the footage or setup the prefs. (gotta scrounge usage of my daughters Win 7 Laptop to use the software !)
These! Just need to book a dry evening for my tyre guy to come fit them
Which tyres did you go for?
They are just comically oversized given the engine power. Not a good power to tyre ratio IMO, it's a normal BMW thing though. Same tyre size across the range of engines.
Next time you've got the car jacked up (and on stands) lie next to them, quite imposing then!
Or bounce them before they go on the wheels (yes I'm easily entertained)
You could have really small hands though![]()
! - Medium hands![]()
