- 29 Dec 2004
- Shepley
Probably not going to be good for espresso, but would be OK for Cafetiere/Aeropress I imagine.
Looking at the reviews, and as One More Solo said, I wouldn't get it if used for espresso (possibly due to it being a stepped rather than stepless grinder). Other than than, it should be fine, certainly better than a blade grinder.
Does anyone have an opinion on the following :
http://www.hotukdeals.com/deals/del...-john-lewis-with-2yr-guarantee-for-32-1784234
Just ordered an Iberital MC2 Noir grinder and very shortly the Gaggia classic![]()
I picked up some more beans today from the local coffee shop were I got my aeropress and other start up gear from, it cost £10 for a 350g bag, sounds expensive to me.
Do you think it would be better to buy online at hasbean etc?
Squaremile beans are amongst my favourite roaster and I've had very few coffees from them that I don't like. However, they usually have less of a range than hasbean.
Also, in terms of pricing their bags are 350g, versus hasbean at 250g, which accounts for some of the difference in price.
Millennium point? Is that by the IMAX?
Awesome choice. I have the same setup and it can crank out great coffee once you get it adjusted and used to it![]()
Can't wait, got a torrefacto blend ready and waitingGonna go down to Sainsburys to get some cheap beans so I can adjust the grinder.
Does anyone know if the Classic comes with a tamper?
Might have to try and make it to the london coffee festival this year (before moving up your way in the summer Flibster) - keep meaning to go but never seem to get the time![]()
After 5 years with the Gaggia Classic and MDF, I thought it was time for a bit of an upgrade
For my Aeropress, I use 17g of coffee (weighed before grinding), put it into the Aeropress, and then fill 3/4 full of water.Finally got some scales. Any quick tips for coffee/water ratios for clever dripper and aeropress.
My grinder spits out 22g of grounds on one press. Can adjust the timer on it though (iberital MC2)
