From your other post you state  ''after looking at all the benchmarks etc. that kaveri's CPU (streamroller core) performance is a bit of a flop and the only worth while kaveri apu's are the 45W models?''
You are right about the lower wattage Kaveris not being far behind the higher performance Kaveris, I agree. But you aren't looking at what an apu essentially can do. Hence you are still ignoring the hsa and benefits of cpu-gpu compute, because you mention once you hit 7850k level you might aswell buy a powerful cpu and a lower end gpu.
That would only work out if your intention is to only game.
If you buy a haswell dual core or haswell i3 and a discreet card you can gain a better gaming experience, but once again you're not looking at the whole point of an apu and its merits. If Kaveri had the gddr5 onboard, then you wouldn't need an intel or amd am3 and a discreet gpu for budget gaming, furthermore when software makes use of the hsa architecture the apu will provide better performance than the haswell i3/dual core.
