MSI R9 290 / 290x gaming edition - powertune throttling the core clock discussion...
Are you on 13.12 WHQL mate? Does it do the same thing at stock, or only when overclocked?
No it looks like something is conflicting somewhere.
One things for sure, you're using an old version of msi afterburner. So uninstall that, restart pc then download and install the latest beta. Copy my settings then report back.
http://www.guru3d.com/files_get/msi_afterburner_beta_download,20.html
The download is saying eta 2 hours! LOL So just to clarify the latest version of AB, should simply let me set power to 50%, clock to 1077mhz and hit APPLY, then the card should be locked at 1077mhz in games?
I've been trying to, but I cannot get a version of afterburner installed that will show the AMD compatibility properties. I just get error "Some of MSI afterburner components expired" when I try to update. Tried uninstalling, registry clean etc just can't get a new version installed.
If I set UnofficialOverclockingMode = 1 I get screen flickering.
My core core clock is stable at 1007mhz in stress testing but is all over the place from 700mhz-950mhz in games.
Is this lowering my FPS? Temperature is around 60 degrees or so.
The clocks should already be set at whatever your default clock is. You should be able to use a set clock, with a power limit of 50% and not throttle. At least, i can do that and i have reference cards that definitely don't cool as well as yours. The card should be able to clock down safely at idle to 300/150 and then ramp up when needed. Are you on 13.12 WHQL?
That means you're using an old version if its saying that. Shut it down so its not in the taskbar then uninstall via add remove programs. Restart pc and download beta 18 from the link i posted above.
This is the reason why you don't use unofficial overclocking. If you do use unofficial overclocking you need to select without powerplay support. That will cure the flickering. The flicking is because you're using an overclocking API that amd does not support any more. They stopped supporting it back in 12.2 drivers or something like that. Running without powerplay support stops the cards from clocking down and that stops the flickering. The flickering occurs when the card changes clocks rapidly.
well the core running at 700mhz worst case is like a running a 290 underclocked ;)
See page one my fps really suffered with all the throttling, as soon as I forced 1077mhz with unofficial overclocking mode no microstutter, solid core mhz, and far better fps.
Letting the core drop to 700mhz in games is akin to a 35% performance hit! all because powertune wants to keep the temps and noise in check!
Yes i'm on 13.12 none beta.
So your core is a constant in 3d mode, never fluctuates by even 5mhz? I'll continue with the download if so, its still 30 minutes off :D
Alternative download link for the beta if the other one is slow. :)
http://download1.msi.com/files/downloads/uti_exe/vga/MSIAfterburnerSetup300Beta18.zip
Have you guys tried flicking the bios switch to position 2? Worth a try maybe. Maybe the card is running in quiet mode. Even though the 290 Pro should not have a quiet mode, i guess anything is worth a shot. :D
EDIT
I found the leaked 13.30 beta drivers caused throttling for me, exactly like you guys mentioned but they're Kaveri drivers and not for discrete gpu's. Uninstalling and going back to 13.12's worked fine with zero throttling, even at 90c+.
i'm two minutes off that AB beta link from guru3d being complete.
Not sure if the bios switch works on 290 gaming edition? it was disabled in reference 290.
Don;t remember it fluctuating at stock but can't be sure. I'll have a look when I finish work tonight. It's not a massive hassle I suppose and I don't think it's affected performance at all but it just seems weird that this is the first card i've ever owned to fluctuate at all.
If is still occurs you can try using gpu-z to do the core clock monitoring and try running it without afterburner running. Just to make sure afterburner is not causing the clock fluctuations.
Could be. Have to say I much preferred GPU tweak to AB and never had any issues. Quite like the OSD though :)
I'll try all you mention tonight although I got a black screen within 10 mins of installing the card box after loading GPU-z and since you mentioned steering clear of it in the 'MSI 290/290X Gaming Edition Thread' things have been fine on the black screen front :)
I'll try it though.
I just did a run through of Unigine Valley. Clocks don't budge as you can see. The only difference is, im running crossfire. I'm also using a lazy/quiet fan profile. Only if i let temps get to 94C will it start to throttle. At 50% fan speed on the reference blower throttling (if it occurs) will drop the core anywhere to 947mhz-975mhz typically. It does go lower sometimes, but don't think ive ever seen it go below 925mhz. Temps got up to 85c on both gpu's on this run.
13.12 WHQL
CCC untouched, default settings. Overdrive remains locked. GPU-Z off,
Yeah man, I can see from your screenies. May be Xfire is the reason? Maybe I need to buy another 290...... :D
I'm going to crib your settings word for word when I get home and see what happens.
I will have to test single card. Its annoying as i hate taking my system apart. I suppose i could just disable Xfire, but id still have the other card connected and card one would only be running at x8. Not sure if that would have an effect, but you never know.
Try this,
In afterburner, go to settings, unofficial overclocking mode, select -Without powerplay support.
Next make sure power limit is maxxed in AB, dial in your overclock of 1077 on the core, hit apply and save the profile if you wish, next go into CCC and enable graphics overdrive, make sure the powerlimit is maxxed out in here too if not max it. (should be 50%).
Now try a game and see if the clocks drop, i use the above settings for my 24/7 oc of 1150/1400 and my clocks don't move a mhz.
is this normal that my idle temp is a lot higher than it was before? its now 48c and before was 35c
also will this nonsense be fixed with driver updates, amd and AB soon ?
