In what way?![]()
Ever used Synology software? if so then you'll know. If not your missing out![]()
I'll install it then on a Virtual machine in Hyper V on my microserver then and check it out
Can you do that?![]()
try the demo on the synology site.Thank you all so much for the suggestions, I will see if I can try out all three, unRAID, Windows, and Synology DSM.
I guess my next dilemma and question is this; as my current Synology NAS has the two 2TB hard drives in it full of data I was hoping to be able to transfer this data to the two 3TB's once they have been set up in the microserver. Then once all data has been transferred I want to wipe the 2TB's and put them into the microserver as well. Then my thinking was I could expand the array in the microserver along with the 3TB's, is this possible?
Unless there is a better way of doing it? With unRAID does it allow hard drives to be added at any point? Same applies to Windows (+ stablebit) & XPEnology?
Stablebit is an awesome place to be on WHS, I've got Drivepool and Scanner, buy both and you get discount pricing..
I like the way it doesnt mess about with the data as well, if you pull a drive the files are still accessible as it doesnt stripe or spread the data around...
Not a lot of UnRAID love in this thread but it's been working great for meRight, im abit confused on what to do, I currently use storage spaces on my home build server, but im ready to migrate everything over to the microserver (everything backed up to an external hdd).
I run esxi and store my VM's on an ssd. So far I have been messing around with XPenology and I have a windows 7 VM installed. The XPenology has 2x500gb with rdm for testing while the windows 7 has the 250gb drive rdm
When it comes to moving the hard drives over, I plan on removing the above drives, then re-adding my larger ones from the old server. What I need t know is if I want to add more drives to the XPenology, will I need to rebuild the full array everytime, or does it allow me to just add more drives to the pool (running in jbod config), or am i better off getting stablebit and installing that on windows 7? I'm right in thinking I can add more drives to the stablebit pool at any time?
I've just ordered one of these while the £50 cashback offer is still on and got a 2tb disk to go in for now.
It will be replacing my buffalo livestation nas which has been good but I want a bit more flexibility and after reading through (most) of this thread I couldn't resist
Question is, if I'm only using it for media sharing throughout the house is there any need to use anything 'better' than win7? (I've got a spare retail license here so would be 'free' so to speak). I like the idea of stablebit so will go down that route as I add more HD's.
I would, perhaps, like the idea of automated backups from 3 other pc's in the house so what would suggestions be for the best way to do that?
Thanks in advance
Lumey
£35? didn't realise it was that cheap. makes it a no brainer I guess
Off to do some googling to find it then!
edit - will it run with 2gb of ram? wont be taxing it much really, I see the minimum is 2gb
