Motorola Moto G - new budget smartphone champion?
I have noticed that if your hands a slightly greasy it's hard to remove the stains from the back of the phone. My advice.. Make sure you have clean hands before handling a Moto G ;)
I wish they would release a back cover which had the same texture as the flip cover but without the flip bit. Would be great!
My phones not powering on and im getting a little worried now. It was low last night so i stuck it on charge with usb cable as u do. When i wake up it didnt charge and was 1% and switched off shortly after 2 mins of usage.
Then i went and plugged usb in again and it lit up with a battery image as it does for charging and said 1%.
Now i left it for a hour and it wont power on when i hold power button any more. Also doesnt matter which usb port i use for it.
Whats happened does anyone know.
Last sign of life was the front white led came on for a bit when i plugged it in then that was the last i saw of activity.
Use a proper mains charger, the usb one just isn't man enough to put any charge in.
Contrary to what mobile makers think not everyone has a wall charger before buying a phone.
If i need one does anyone know which one i need, i heard somit about needing a stronger than normal charger perhaps but i have no idea about chargers tbh.
