- 5 Sep 2011
- Surrey
Hi All,
the KP card is very limited, there are less then 100 Units for whole Europe and it is not meant to replace the "normal" Classified.
The KP card is meant to get overclocked hardcore with LN2, Dry Ice, Facechange...
Of course you can also run it on air or water but the advantage compared to the Classi is not that big with normal cooling.
You can also still have Ref cards with good chips on it, there are ref cards that do run without voltage tweak 1250 out of the box so it do not mean you will get a "bad" GPU if you buy a normal Ti.
All due respect Dominik, and I know this isn't entirely EVGAs fault. The 780Ti is a very good overclocker. There are ref cards that will do 1250mhz to 1300mhz on air with stock voltage, correct. But if you take into account the OVP OCP protection that NV refuse to remove on these cards with the Classified, and that your binning process is essentially 1300mhz at 1.212v. Then you're not really getting a lot more card for your money. For the sake of the extra cost you may as well gamble with a reference card, which could quite possibly get those clocks anyway. For example one of my SuperClocked cards will do 1316Mhz @ 1.212v. Unfortunately I'm not able to put anymore voltage through it, when there's no real physical hardware limitation on it over the Classified with it's better voltage controllers.
I think the fact these cards-do clock so well has allowed you to create this 3rd tier card, put better voltage controller, uprated power converter for 450W and charge considerably more for it in limited quantities. If it wasn't for the fact the Ti had such better power circuitry as a reference design this obviously wouldn't of happened. Thus the previously top of the line Classified has been surpassed as the card to get. Of course if you're lucky enough to get hold of a working Evbot that's not so bad.
I'm feeling that the reasoning for this is a lot to do with Nvidia not allowing you to remove the voltage regs and that in itself is not your fault, but I think a lot of Classified owners feel a little short changed over it.
