When is outlast coming to psn+?
I'm starting to really hate the ps4, currently playing online battlefield, when I go to the hub to see online friends, it just doesn't load. Getting sick of the problems.
Is it then on for a whole month?
Might get a ps4 tomorrow but not psn+ for a week or two.
Maybe grab a 14 day code off someone here!I presume youve read the DF article by now then antiIs it then on for a whole month?
. Youll have til near end of the month to get Outlast, but Id recommend getting PS+ for Dont Starve too if you havent got the PC version...
If thats the case just hold off the PS4 and just get PS+ and use the PC webstore to add it to your account...Lol, read it, but not fussed about TR, played it on the PS3 and don't feel like double dipping for it. Maybe if the ending was better.
Was going to wait until Driveclub but I really want Outlast so might just get one now and be done with it.
Yup nothing loads, they really need to work on that. PS3 had similar issues.
Do we know how much tomb raider is going to be digitally?
Which I don't think will be that bad once the suspend/resume feature is put in.Argos are doing a PS4, Killzone and Fifa 14 for £430 and they have stock locally. Does this sound about right?
Just tried out the HDMI-Link thing as I had no idea what it did. I like how if I turn on my PS4 it turns on the TV and to the right channel and found it funny that the remote could control the home screen (and badly)... but then when I accidentally turned off the TV and it then put my PS4 into standby, well... that was kind of annoying to say the least!Which I don't think will be that bad once the suspend/resume feature is put in.
I found it terrible tbh, say if I switch sources on my tv from Sky to PC, PS4 is in between them. Every time the source changes to PS4 when going through them the PS4 will turn on when I don't want it to, I'm simply switching sources.
It's only great if you use your tv for PS4 only imo. Otherwise it's easier just to turn it on and off normally than having it switch on all the time when you change sources.
