What?? So my psu is struggling???
As 8pack said - once you apply the volts - PSU's quiver
Which one do you have?
OCP on cards!!! or PSU!! I just warned you man!!!! Yes it will be struggling. Nvidia low power consumption!! NO and NEVER!! You overclock you need silly power. For 1800 on my card I needed 1500 Super Flower on one card!!!
It does not actually matter which one you have. Volts and frequency 1200w quality per card is needed. Voltage spikes on coming out of a bench where the card dumps current back are massive!!
This weekend I am gonna bench with one 1200w psu per 8 Pin connector. Seriously!!!
Why do you all think Nvidia wants no more than 1.2v per card. Its not just because of RMA its also because of the PSU problem etc etc knock on effect.
1000w Seasonic, great unit but not strong enough.
No I dont have a monitor but I know for a fact its your PSU or OVP/OCP on the card. I have tested a lot with this card. It has crazy current peaks.
Thats just insane!
don't forget vantage!!Tadon't forget vantage!!
Haha, I try to forget Vantage but Geeman keeps reviving it![]()
more to it then just your gfx, just takes too long
I like itmore to it then just your gfx, just takes too long
PSU is the problem mate.
