Yea, last time we didn't lose anyone, at one point it broke into 2 groups for a short time. But common sense normally prevails.
We will stop off for petrol at least halfway where we can chill for 30 minutes allowing anybody lost time to catch up.
The part on that vid that stuck out most for me was the fill up even if only half full.
Many times mates of mine when I used to ride in groups wouldn't bother filling up if they had half a tank. This slowly resulted in multiple fuel stops for the entire group. If everyone is full, everyone can achieve the same distance if it's reasonable. Typically, if you need fuel, just signal someone and they can normally signal ahead and so on so the leader knows to stop for fuel.
Yep, 100% agree. Being half full can be a right ballbreaker for slowing things down. Just hope i can make it half way way even with a full tank lol. As Agnes will know, a 1098s "making progress" is not that well noted for lack of fuel consumption
(Have my daughter at weekends, need to sort out with her which ones)
Most I've ever spent on a 'upgrade' for a bike. But finding a second hand one is just impossible. BUT, it's from the original bike budget as I put aside enough to buy a new Panigale 1199 or new Multistrada 1200S.
