And as I mentioned on my forum, so will your monitor be in the long run.
yep it was just the way i was using it rather than anything else, i realise now that vsync on and a decent gpu and there isnt much call for 144hz at all
My battlefield gameplay isn't smooth now after Iv done the mantle update and using catalyst 14.1 drivers, very sad.
Also I did a test for the monitor LG 29 inch and only managed 60hz with both my hdmi and display port cable 2560x1080 even tho my catalyst shows 75hz, so does that mean my game runs at 60hz or 75hz? Any software to test?
stick to using displayport only.....
and use fraps and cru it should work, works for me.
I am considering a 21:9 as my next monitor but after a lot of googling I'm still not sure if counter strike source will resize to 21:9, as this is the main game I play I wonder if anyone has tried it or can confirm it works ?
It works fine for me in 21:9 looks great
That's good to know, I presume you have to do some sort of resolution hack to run it?
Just purchased the Dell 29". Was a close call with the u2414h, however with all the issues I've read on it and seeing the issues first hand with a friend on his 3rd monitor I just didn't want the hassle. Really excited and can't wait to get this in and take my Benq G2420HDBL out.
It's a superb screen, you'll enjoy it. Yes it's a bit narrow vertically for work/ desktop stuff, but for the sheer quality of image, colour rendition and the super wide gaming, oh the super wide gaming - it is ace.
Problem is it's got a big brother coming out soon, with 1440 vertical res, and I just know I'm going to want it. Never satisfied.
Recent games stutter a lot more due to the extra pixels so you need a very fast PC with SLI or Crossfire ultra high end cards & the best CPU you can buy along with a stonkingly powerful PSU (basically £2-3K worth minimum!).
Crysis3, Far Cry3, Assassins Creed4, Batman Arkham City. All are fine @ 1920x1200 but a single GTX780Ti is not enough to get the same smooth FPS without a lot of stuttering @ 2560x1080 IME. With vsync enabled there is no point having vsync disabled or adaptive vsync when you get such horrible screen tearing which is even more noticeable on the Asus 21:9 panel IME.What games stuttered? did you have vsync on?
