Guys, fresh Video from Germany.
Under Windows 8.1, Mantle is destroyed... (Direct X 11.1 is the key)
Nvidia clearly wins here.
Wonderful demonstration of the Mantle effect. Make sure you watch in 1080P/1440P/2160P quality.
The 290X in the Video always uses Mantle and you can see that the performance drops a lot when using Win 8.1...
R9 290X
Win 7+Mantle = good
Win 8.1 + Mantle = bad
GTX 780 Ti
Win 7+ DX11 = not so good
Win 8.1 + DX11.1 = good
So, it looks like, that Mantle isn t optimized for Win 8.1 but the Nvidia Cards are getting a huge performance boost with Win 8.1 (here 780 Ti + 20 FPS) and the gap is closed that Mantle created.
At the end of the video he got a problem and couldnt test @ Full HD and Mantle under Wind 8.1 with 4xAA, he said that he got 50 FPS so he didn t show that etc...
Recently got an MSI R9 290 Gaming so was keen to give the Mantle drivers a go. Had an issue with the card in that one fan was stuck so temperatures were getting to 90oC and assumed that was the reason for frequent crashes in BF4. Once the temperature problem was resolved I continued to get crashes with the game freezing and then reverting to a black screen - I had to use Task Manager to shut down the BF.exe to recover from this). Strangely though there could be long periods of stability for an entire evening and then the following morning crash after crash after crash; there is no sense to it.
I decided to go back to the last set of stable drivers (13.12) and stability has been excellent but I do notice a drop in FPS; which I will take for the time being until Mantle is sorted.
It looks like Mantle could be good but I think the Beta was released too early; cynically I think there was maybe a deadline and the focus was on hitting that rather than being brave enough to say its not ready yet.
Andy
Looks like Thief will have Mantle from the get go.
TrueAudio
As this game will be out on the 28/2, so Mantle 14.2 should be out soon and hopefully it will fix the bugs
lol you couldn't make that stuff up above, Matt posts a video showing Mantle's benefits then 2 minutes later Duvar posts a vid saying it's worthless if you use 8.1
This forum is brilliant at times.
I am not too bad at German and can understand most of it.
I wish i could say the same...Been gaming with my German mate for 3-4 years, always on Skype and know probably less German now than i did back then
Luckily he speaks better English than half the people i work with!![]()
When it is slower, it is much easier for me to understand.The 290X in the Video always uses Mantle and you can see that the performance drops a lot when using Win 8.1...
R9 290X
Win 7+Mantle = good
GTX 780 Ti
and i start BF4 after fps is all over the place CPU usage jumps and ****.
