2 x 4GB Crucial Ballistix Sport to go in my N54L.
I thought each drive was max 2TB??
Perhaps that was an earlier model?
Thanks - if I don't want to do this can I install an SSD (presumably in non ACHI mode) onto the "optical drive" SATA port and install Win7 on that drive - or doesn't the optical drive SATA support a hard drive / SSD please?
Thanks, Mel
What do you intend installing where? i.e. where will you plug in the SSD?
Can you advise (using sign language if necessary) where you bought the HP Proliant please - there seems to be one cheap place an several at £100+ more - before the £100 off!
Thanks, Mel
Thanks, Mel
Thanks, Mel
should be one last result on page
Thanks, Mel
[RB];25823707 said:Just want to advise against this as it's *rediculously* slow.
I appreciate flashing the BIOS isn't for everyone, but if you're going to use an SSD you'll pretty much have to![]()
So if I don't want to flash the BIOS, I use one of the 4 sata ports for the SSD and the other 3 for good old fashioned HDDs.
Is there a max TB that can be used
3 x 3TB OK ??
Thanks, Mel
Is the N54L a worth upgrade over the N36L? I have my N36L setup with Ubuntu, SickBeard etc Does struggle with transcoding via Plex
I suspect it'd still struggle with 1080p - my N40L is ok with 720p but a LONG way from being able to send 1080p.
I'm hoping to get a G8 microserver at work soon for a vSphere lab so I may do some testing there to see if it's beefy enough for 1080p
