I still miss my Mini, was a little beasty
Very OEM and unassuming from the outside, based on a 93 Rover Sprite but under the bonnet:
1380cc, Omega Cast Pistons, Kent MD286 Camshaft, Ni Tempered and reground Crank, Lightened Flywheel, "Stage 3" Head (Valve sizes 35.7 / 30), 1.5 Roller Tip Rockers, HIF44 Carb, Maniflow LCB + Superflow exhaust, Aldon Yellow Distributor, Aldon flamethrower Coil + Ignitor Elec. Ignition, Jack Knight S/C C/R Gearbox, S/C drop gears 1:1 ratio, Semi Helical Crown wheel and Pinion 3.44 ratio, Crosspin Diff, Turbo Clutch.
Longmans tweeked to 89bhp@wheels..
Took all of the interior and sound deadening out. You used to floor it and the world sounded like it was ending while you squirreled off up the road
Stripped it down to rebuild with loads of nice KAD, rose joints, aluminum doors, kirky buckets, SD cage and other shiny bits but got a mortgage shortly after and had to sell her
