I think you're not getting my point or you're purposefully arguing a straw man because everything you're linking is AMD DX vs Mantle or multi-GPU or both. I'm not saying AMD haven't improved the situation. What I'm saying is that the place they have improved it to, to me, was not noticeably different from nvidia's DX version. Whereas we could tell a difference between AMD Mantle and AMD DX they (AMD Mantle and Nvidia DX) were roughly equally as smooth at 100-110 FPS (ish). We don't have multi GPU to test that angle hence no comment on it. The gains there look impressive.
Thanks for the link at last. The graph at 1080p (what I was looking at myself as only noobs play at 60 Hz
) is more interesting to me.
They all have low frame times but anyway this isn't the 14.1 driver so it's not a correct comparison point.
Not sure why they're suddenly a touch higher at higher res, no comments to explain.
Anyway these graphs aren't showing frame consistency just 99th percentile which is different. Also the difference at 1080p is a couple of ms so not that noticeable a difference.
They're higher at higher res because it takes longer to render the frame at highert res. Lower frames, longer frame times.
AMD have better frame times in this game. This is single gpu we're talking about here, not multi. There will not be any of this inconsistency you seem to be mentioning. 780 has longer frame times than a 290 on DX. Mantle lowers the AMD frame times further and it also lowers cpu rendering times meaning a smoother output. This will show itself in smoother performance via lower rendering times. If AMD have lower rendering times before Mantle, they will not have higher rendering times after it.
