This weekend I made what looks like actual progress!
Engine bay was sprayed in satin black, I still haven't decided on an actual colour, this enables me to start fitting more of the oily bits.
Last weekend a friend cleaned up the crossmember with a wire brush and gave it a lick of paint while I took the rest of the suspension apart. Turned out the wishbones were beyond repair, all the bolt holes had elongated to oval and two had cracks. The kingpins were also a sorry state. Not having the correct reaming tool or the desire to splash out on one I bought exchange king pins along with polybushes, wishbones, ARB links and springs. Lever arm dampers were emptied and re-filled with oil, if anyone has suggestions of the best oil to use then please let me know. I just used some hydraulic oil. Steering rack was also given a lick of paint and replaced the balljoints.
Cleaned up crossmember and rack fitted;
Pile of bits awaiting fitting;
All fitted along with new discs, calipers, bearings, seals and braided brake hoses.
handbrake and rear brakes have been fitted and steering column bolted in place.
That's all for now
That's all for now
