Good work Kaap. I think highest temp should be at the top though.
EDIT
Maybe you should state Reference Air, or AIB Air etc?
If people state the above I will.
Kaap, are you running two MO-RA3's on that rig?
Yes
EDIT
Table updated.
@LtMatt what kind of air cooling are you using, ref or non ref ?
Kaap you know im rocking reference cooling.![]()
I also know you are an ace modder, I was not sure if you have enhanced the cooling.
I will put you down as ref air.![]()
And on the table.![]()
blower cards do quite well when up and down like his pic
