Well humbug ur suggestion has worked a treat but with a lot of fiddling and messing with the settings. Finally got it working on all High settings with 2xMSAA @ 1080p and wow it runs like a dream now. Solid 60fps with vsync enabled and thats even on a shanghai 64 player full round. With these settings im seeing around 2.4GB VRAM used and if i use 4xMSAA it'll be around 2.8GB VRAM and still a good solid 60fps with an odd dip in the high 50's
I have switched back to running my 2 1080p monitors from my 7950 and now the 300/150 idle clocks are back when in Extended Desktop Mode.
I cant believe how smooth Mantle is running even in the most intense dusty parts of Shanghai.
Thanks for this awesome tip humbug. I never thought lowering the settings would actually fix my issue. Cheers man
On a side note i was getting locks ups running dual monitors until i actually went into CCC and set up the AMD Eyefinity Multi-Display. I couldnt alt-enter before this but now its running peachy.
Happy chappy nowLets hope they fix the memory leak soon. I just know Ultra is gona run well on my system now
Good to hear.
The 'Mantle effect' cannot be overstated enough.
