Plasma vs LCD:
How many of the brought-forward figures are actually tested, I wonder? Because indeed, the real-world tests are the ones that matter. So if anyone is more interested, I would encourage to buy a watt-o-meter with a kWh and/or Cost mode. You know, the ones that you plug between the wall and the device, and they will calculate the necessary information (the basic models cost like 10€, I think). Then just keep the television (be it LCD or plasma) on for 10 hours, alternating with regular broadcasts, movies, maybe even some computer time.
And please don't temporarily change your current settings for "economy" or "energy saving", we want to know the real world values. And please state your model number, too.
For example, my Philips 42PFL6907T (42" LCD, 2012), takes about 80W, which is pretty much the max achievable power draw from it. With about 10h daily, this amounts to 290 kWh annually.
-- 80W in both 2D and 3D, no matter the source material
-- with only one change, it would take only about 45W (165kWh/a) if I simply let the backlight go into a PWM-mode by enabling "Dynamic backlight", but I'm a bit stubborn, so I won't let it
-- with a few extra changes, I could get it all the way down to 35W (130kWh/a), and even without any noticeable image quality difference, pretty much only affecting the PWM
So while it is indeed possible to specifically fine-tune a plasma to use less than 200W, the same analogy applies to LCDs, too. If we make compromises with the features and settings, then yes, we can get it way below the norm. But I thought that plasmas were all about not making compromises with regards to image quality?
-- in other words, please test with your actual settings and in real-world scenarios, don't cherry-pick to prove a (false) point
-- if you necessarily want to cherry-pick, you might as well blatantly lie about the figures, wouldn't make a difference
And the power usage is indeed important, as you can reasonably offset the electricity bill savings to the TV purchase, itself. In essence, you might end up comparing a 600€ plasma to a 1000€ LCD. That's the difference it makes.
But also note that the offset cost hugely depends on your
a) average daily usage
b) planned lifetime of the device
c) your electricity tariff
From what I've seen, plasmas draw about 4x more power in AVERAGE when compared to LCDs of the same size (both using calibrated settings).
Or if there is someone who would like to refute the figures, I would insist that the same person would kindly provide us with better figures, as in my opinion a review site (hdtvtest.co.uk) that focuses solely on HDTV tests (plasmas and LCDs alike) should be quite a fitting choice for the average source data.
As for the FG2421:
Forgot to make an update to the first post that now they're on stock at OCUK.
Scratch that, seems like I didn't forget, after all. Updated and cleaned up the first post now even further, though. Also: normally £450, but this-week-only-offer has them for £420.
