- 4 Nov 2013
Good to hear. BSOD will be nothing to do with the bios though, all the bios does is increase the cards low TDP and remove the boost part of the bios. Nothing else is changed so any system instability will be as a result of something else.
I see, probably it is the XMP mode / I have changed the ram setting from 'auto' to 'ddr3 800mhz'.
I will try to change it back to 'auto' and keep xmp setting and see what happen.
Regarding fan setting, should I keep it to auto or there is a good guide to follow?
