OK. I think I'm done with my ENB version.
If you want to give it a shot then the link is
Code:
[url]http://www.sendspace.com/file/t4laaq[/url]
or
[url]https://onedrive.live.com/?cid=1b1ca31d1d85130b&id=1B1CA31D1D85130B%2112284[/url]
. Included in the .RAR file is ENB v251, ENB Helper and the core files. So, everything you need to get it working without having to search nexus or enbdev
Just unzip and copy all the files to the skyrim.exe folder.
And don't forget the Skyrimprefs.ini.. alter the usual bFloatPointRenderTarget=1 , trees shadows, land shadows etc to taste.
I've altered the sky brightness, made clouds and sky dark at night, made mountains darker, added bloom, removed bright water at night, basically made the vanilla skyrim what I think it should be but keeping with the same style and colours of the original game.
And I recommend using it with "Remove Interior Fog V2" mod on the nexus.
http://www.nexusmods.com/skyrim/mods/29253/?
Not to be used with anything that alters image space lighting.. RLO, ELFX etc. Works fine with colour adjusters such as Imaginator etc.
and some pics..
No texture mods apart from character skin/hair mods used in the pics. All default skyrim stuff:-
