- 30 Sep 2005
so I can therefore accept it to be page 0
Having looked it up, a cover is not a page.
Real Numbers GB US
2 2 3
1 1 2
0 GF 1
-1 L1 L1
-2 L2 L2
You can accept a dolphin as a shark but you'd be wrong.
That's simply not how it works
the floor is an ITEM, it exists. When Nestle make kitkats, the first one off the production line is ONE. Not ZERO.
When a builder builds a house, the first floor he lays is ONE. The first floor. If the house isn't a bungalow, then the next floor he puts down is the second floor.
You can call it the ground "floor" if you like, but it's number one.
ZERO means a floor doesn't exist
Going by that logic, the lowest basement floor of a building should be 1 and all floors counted up from there.
Clearly that isn't the case so you must be mistaken.
The floor concurrent with ground level is the datum, hence being designated 0 and floors above and below that are numbered sequentially.
Code:Real Numbers GB US 2 2 3 1 1 2 0 GF 1 -1 L1 L1 -2 L2 L2
When a building has no levels below ground the level numbers are scalar, or unipolar, ie. all values are in the same direction from a fixed point. All three systems above work for this scenario. Interestingly (!) the GB & US systems require an implicit zero in order to satisfy the set theory conditions for addition. Zero is the additive identity. The US & GB systems are mappings.
If the building has levels below and above ground the numbers are vectors, or bipolar, ie. there are two directions from the fixed point. Zero is then absolutely necessary as it is the state of 'neither direction'. In this scenario the real numbers work perfectly. The GB system maps zero to GF but the US system can not map anything to zero without losing ordinality. Consequently, according to additive fields in set theory, you can't add or subtract floors so you are stuck on ground... or 1 or whatever
Practically, however, it is hard to imagine a situation where a person might have real problems with any system.
SNOOGINS![]()
a floor is still a floor be it marble, concrete, wood
a chocolate bar is still a chocolate bar be it bounty, mars, snickers
when I fall over, do I not fall on the floor?
what's wrong with mars bars?
ok, so they are half the size and twice as expensive as those in the 80s.....but still a decent chocolate bar
a mars a day, helps you work, rest and play!
or should it be work, rest or play!
How can you work, rest and play at the same time
You completely ignored the point I was making.No, because a basement can be added after the first floor has been laid. My house could have a basement added to it (at great cost obviously).
This is why the American system works so well
You are confusing the use of numerics as a measurement, against the number of floors built in order.
The builder puts the FIRST floor down. That is floor number one. You can label it what you like, the fact is that is the FIRST FLOOR.
If you you to call it secret underground NSA spying floor, so be it.....it will still be the first floor
If you want to call it secret underground NSA spying floor, so be it.....it will still be the first floor
You still didn't get it.
so if I build a house, how can I do anything other than put a floor down first?
You can't build a second floor first.....well, I guess you could get a time machine jump forward a week and lay your first floor second.....but in doing so, would there be a first floor as you have jumped over that week?
