Since when was the gtx780ti nearly 40% faster than the gtx780.
Lol good spot.
Don't ask me lol, I just see the image on [H] and I couldn't be bothered reading
Edit:
In fairness, looking at the results in this thread, I doubt they bothered to use the bench and just played the game, which has insane fps compared to the bench.
I would imagine those 780Ti frames are about right though, going from my in game frames.
A stock 780 boosting to around (920-940) is massively under what they're capable of whereas a Ti (like the 290/X) is more tuned from the get go. Does seem like a large difference though.
HardOCP aren't using the highest in game settings if that is their numbers. SSAA can be enabled at low or high and will drop FPS dramatically. With SSAA high I am getting average FPS in mid 40s at the same resolution.
Get your cpu clocked high Zpaf, seems to help in this bench.
Use IMGUR/Photobucket/Image Avenue/TinyPIC Zed.
Also i noticed the 50% power tune not working properly in 14.2 beta. Luckily i run at stock or with a small overclock.
Report that issue via my sig for 14.2.
So is crossfire working for anyone? I find it pretty ridiculous that an AMD gaming evolved title has little to negative crossfire scaling yet SLI seems to be working ok (not perfect but better).
So much for 'optimised for crossfire'It's starting to feel like Mantle has become a distraction for the fundamental things the driver team should be working on.
Did you not work out OneDrive then Matt?![]()
