Looking good matey, In a couple of your pics though the top cables closet to you, on the psu doesn't look like it is pushed in all the way. Also on a side note the gpu's accesories are usually under the foam.
The colour looks like it's matched pretty well actually, certainly near enough that you wouldn't really notice. Build's looking good man![]()
Its been Tango'd !
Yep I'm still liking the orange, how much did the chair set you back, if you don't mind me asking? Mine has seen better days, although its a long way to Ikea from my place.
Coming along nicely
That is a sweet first rig! Love black and orange builds!
Will get some pics up soon now i've modded the case abit so stay tuned
Surprisingly, my temperatures haven't even dropped and if anything my GPU has gone up by 1 degrees :/ All these temps are at idle so i'm guessing this is just room temp and hopefully the new fans make a difference under load. Only real difference is an extra 140 at front for intake.
On a side note, does anyone know how to get the hard drives too come back on corsair link? I've seemed to have lost them and even after selecting 'show all hardware' and maximising the window, i can't locate them.
Yeah, it just sounds like room temp + a little heat generated. Nothing to worry about on Idle, they are good temps.
And Corsair Link has a mind of its own... I uninstalled it as its unnecessary, and caused some blue screening now and then. Possibly due to interference with BIOS settings for fan speed, not sure. But icons would go missing too. And firmware updates failed to notify of success, just kept updating till I closed the program down, and then opened again to check firmware version to see if it had worked (guess it did but leaves you with some doubt as to how successful it was). Don't want buggy software on my computer, unless it's absolutely necessary.
Then again, I haven't tried the program for 8 months or so. Might be an update for it. But I don't want to mess with it again.
Looking grand mate. Now I wonder how you could mod the superflower to light up the power cables orange instead of white? It should be possible. I'm just guessing here but you could either open the superflower up and cover the LED's with some sort of orange transparent film (no doubt voiding warranty though). Or you could cover the plastic clear plugs in some orange film or paint them with some orange clear lacquer or something?
Would look amaze if you could do that!
Nice,the orange accents look really nice
Yer, that's something I'd love to do mate. Like you said though, wouldn't know how best to go about it. I think modding the actual LED's would be best, but then bye goes my warranty. I might look at adding white light strips to the bottom and top of the case. I think once it's lighted up more, the PSU won't be so prominent. Was looking at Orange lights but think it might just be 'too much' orange.
