Looking at the specs and technical data their doesn't look to be any difference between the Ultimate and the Universal other then the colour of the shroud, is their any other differences ?
I'm thinking of getting one, on the Cryorig it lists the various retailers for different countries, the one they list for the UK looks to be based in Germany even though they have a .co.uk address.
You sure you looked hard enough, the Front fan is 13mm on the Non Ult so it clears Ram.![]()
Sorry, no. Still trying to get my test system back together. Swapped the R1 Ultimate for TC14PE on my sig rig and can't say I'm seeing enough difference to record. Keep in mind my sig rig is not overclocked.
Got a DimasTech Easy V.3.0 from wife for birthday. Thing is huge.. 490x430x205mm (WxDxH) high to motherboard. Think I want something smaller.
Overclock that CPU already!!!!
I had a Cooler Master test bench one but I got rid of it as it was pointless benching on that.
I have never overclocked..well not in many years. I suppose I could use my UD5 for testing instead of UD3R with 920 on it. Don't know if 980 would run hotter or not.
Guess I should get the thumb out and find someone to be my OC Guru and do it.![]()
