Probably still wouldn't make the little bugger chill out - would need an elephant dose
Hi guys, posting this on behalf of a friend. I'm unable to give him any advice as I've never owned a BMW.
He's in the market for a 3 series 330, preferably something like this:
http://www.autotrader.co.uk/classif...price-from/6000/price-to/7000/page/1/usedcars
When asked my opinion the only thing I could really point out is that even if the cars are lower mileage they're still quite old, don't know if that matters though. Told him BMW used warrenty is probably worth getting too.
He's looking to spend up to £7,000 on the car itself. When I suggested a 320 sport etc he seemed to prefer the 3.0 litre 330's, so unless they're a better option for the money I guess they're out haha.
He's basically wondering what's the max price he should be considering for a car of this age (mileage and condition dependent obviously). Sorry I can't be more specific! Thanks for any help you can offer.
Was looking at e92 m3's the other day and wondered... consider this is under £35k
http://www.autotrader.co.uk/classif...chad/used,nearlynew,new/radius/1500?logcode=p
What kind of money do you need to spend on a car more capable than that? I can't think of a £50k car for example that will do everything that will do better?
These are going to be a very good buy at some point!
Goddamnit, I look for a 330 everyday to find nothing, then you come along and find a 54 in a manual and low mileage...
I'd say that's worth a look at, looks nice, and a bit or haggling, I can see you getting that under £6000.
Are you specifically looking for a facelift? It's looking like mine will be going up imminently (though its 120k and pre facelift etc)
Selling my Z4 soon and looking to perhaps replace it with a 3 series. Thoughts on a E90 ('05ish) 325i SE? Are the E90 still considered inferior to E46, seems coil pack, injectors and fuel pump are very common problems?
I know a lot of people think so but I moved from a E46 to E90 and have been very happy with it and think its better in almost every way bar the ride quality most of which will be due to the RFT's
