2nd hand bike for commuting?
Status
Not open for further replies.
Depends on the commute though.
Yesterday I used my road bike and decided to come home on the route I've been taking with my MTB and nearly rattled the road bike to death and nearly came to a full stop on grass & mud.
Road bike again today but I'll have to alter my commute.
And here we go again :p
(just kidding)
Triban 5 does look nice, but if merlin is better then... hmm. Does merlin have any sort of warranty?
I'd go for triban 5 because it looks better price is pretty much the same and components are very similar bar brakes from what I can see and wheels of course.
Are you being sarcastic? :p
If merlin has better spec, then I'll buy merlin. No point in buying a bike just for the looks..
Edit
Nearest Decathlon is in London (around 45 miles away), I'm gone order online anyway.
Edit
He's probably not being sarcastic tbh :p
If there's no local store advantage to be had then definitely go for the Merlin.
I was being serious.. The components are different but I didn't say they are worse haha..
The brakes are worse aren't they? I could be wrong.
The Merlin is cheaper though so for similar spec it makes sense to get the cheaper bike. If the brakes (and maybe wheels, dunno) are better then it makes even more sense.
tbh my triban 3 brakes which in theory should be worse than triban 3 have served well enough for over 7k miles.. and still going.. no cable replacements either.
merlin wants £30 quid for delivery that brings the price up :o but yeah the brake set on merlin at least is official "sora"
these two look alright spec wise too -;
http://www.winstanleysbikes.co.uk/product/61078/Raleigh_Revenio_1_2013_Bike
http://www.winstanleysbikes.co.uk/product/55463/Felt_F95_2013_Bike
I had a felt bike moons ago and the built was awesome on that!
Yeah, Merlin will be 430 and Triban 5 will be 443.99 so not a big difference... So which one is better in terms of spec/performance? :confused:
Edit
Grudas, Do you own a Triban 5?
both are pretty much the same..
merlin has, in theory better brakes, but white triban 5 for e.g. has the same as my triban 3 and they have lasted for ages and still work fine.
wheelsets on both are ??? as they are unknown brand etc but should last 2-3k miles no problems.. I eat wheels for lunch and I killed mine in 1.4k miles
I'd probably go with that green felt in 58cm.. awesome looking bike(seen a few around london) and from my previous experience felt make good in house parts so hubs etc should last for ages.
edit -;
no I own-ish a triban 3 :) but it has been rebuilt a few times due to me hating the way it looked, if 3 is anything to go by 5 will be great and I've only heard good things about 5.. and now 5(white) is on offer at £399 - possibly best bang for buck..
out of the 3 -;
felt
merlin
b'twin
you can't go wrong with either one of them to be honest.
edit -;
out of the 3 -;
felt
merlin
b'twin
Where I usually leave my bike there's a camera, but such a bright green might attract thieves :p. I guess a good lock should do the job, but the bike doesn't have pedals? So I'll have to buy pedals and a better lock, as my lock is poo.
Edit
So, Triban 5 white has 5 years guarantee and is the cheapest
Felt is probably the best looking and from what you're saying is the best, but doesn't have pedals and is the most expensive...
Merlin is (kind of) the same as Triban 5?
That's correct.. No pedals is the normal on a road bike so don't be surprised by it :) you can pick a cheap flat pedal pair for £15
Last question before I order, my height is 184cm and Arm span of 185cm (Ape index of 1.005). What frame size should I pick, 56 or 58? Upper body is 71cm
[DOD]Asprilla;26007632 said:
Can you touch your toes? And what's your inside leg?
I didn't do any sport in past 2 years, so can't really touch my toes. But If I stretched then I probably would. Inside leg is 88cm
[DOD]Asprilla;26008228 said:
If I had to pick one is say get the 56. It's easier to make a bike that's slightly too small fit tha one that's slightly too big.
It might be relevant to this, I've ridden a sccott rode bike with frame size 57cm and it was ok for me. That's another reason why I hate buying from the internet, because I can't sit on the bike and try it out... :(
Status
