Well if the plane is being kept somewhere, where are the 250 people from it?
Dead. Or being kept to hold to ransom at a later date.
So you have 50+ boxes on the rack many of which you have to get inside for maintenance after manufacture. Air flows around all those boxes to keep them cool. If they were all completely sealed to air cooling it all would become even more of a nightmare, let alone maintaining the argon level. This isn't an nice server room maintained to a nice constant 17 degrees. Most equipment bay fires don't come from the internals of a box but external wiring. Argon aint gonna do **** when all that insulation and dust catches fire.
up and also the dive is typical of trying to put out a fire - it does seem very likely that this scenario is the correct one, rather than a hijacking type scenario.
You do all no that the blue stuff on the maps is the Ocean - you know that thing where there are no people to notice a low flying plane and coincidently no mobile masts either to provide mobile phone coverage in the middle of the ocean for the odd passing ship
What do they gain by not saying their demands straight away? If it was a hijacking for ransom money/grand gesture the people behind it probably would have announced it already.
<tinfoil hat>
Keep the passengers alive, load them back onto the plane with a 'dirty' bomb, fly it at the nuclear summit in Genova on 26th March where lots of the worlds leaders are gathered
Watch the west shoot down a plane full of innocent civilians
Sherlock here. Whilst you are indeed 100% correct, and I think everyone else is aware of this, it's not what other people, and myself are argueing.
IF it made it over land and flew at that altitude people would have noticed. Your little theory above would lead to it not making it over land and ditching into the 'blue stuff'. A plane crashing 10 days ago into the sea would have resulted in items being washed up on shore by now. Or atleast debris being found.
In a controlled ditch it should have held together pretty well and possibly sank after that. Although if it did break up the area of ocean is huge and wouldnt be suprised if nothing had been found as it would have dispersed in the following 10 days so it would be a needle in a haystack
And I'm guessing the arc is based on which satellite received it (closest within line of sight)?
Finally understood the satellite ping thing. The satellite sends out a signal to ask the plane if it's still there if it hasn't heard from it for a while. The plane receives it and sends out a signal acknowledging its presence. There is no other data in it than that. That's why it can't be triangulated.
I think the answer to that is along the lines of: How do you propose to 'triangulate' something using a single satellite?
AFAIK they've used the signal strength to get a rough estimate but that's all it is.
I tried to use the plane finder website to find the planes last movements online. It didn't show up at all.
With all these satellites up in the sky, why is it taking them so long to locate it?
