Rilot I have on a couple of occasions had the kayfun leak slightly but this is after using one daily since I purchased it in late January. It's easily my daily go to atty, haven't really used anything else since.
If your looking for cheap / good - Literally for the money I could not be any happier with my budget setup, Basically Clearo's are not very good, various issues, not much taste, and they work out MORE expensive than something like a Kayfun clone or dripper as you have to buy new heads all the time... I have a setup which consists of a C9V Micro-D SS dripper, 2 x black EVOD 1000mah, charger, Total cost = £35 inc wire / wick etc. Flavour from a dripper is the same every time and to be honest clearo's are plain bad compared to a dripper for vapour and flavour. Skip the clearos and get what I just said or if you want a tank then get a Kayfun / russian etc. For a small ego sized setup though just buy what I said and thank me later
I put a 1.6-1.8ohm coil with the 3.7v regulated EVOD's and some organic cotton in the dripper, drip about 7 drips and get perfect vapor and flavour EVERY time, good enough vapour production (much more than clearo's, not as good as a big mod) and perfect airflow and flavour every time for £10 delivered. Honestly the quality of flavour and vapour from any clearo is pretty crap really, except for the Aerotank is good but still lacking flavour and has a silica taste from the heads. I find it more convenient to use a dripper than a tank, no messing about refilling, leaking, change flavours whenever you want etc. You just carry a 10ml bottle of juice with you and whup a bit in there when you want it, This little thing is actually better flavour than anything else I have tried because it is small (smaller dripper = more flavour)
I would honestly take all my clothes off and run down the road telling everyone how much I like it and what excellent value for money vapidge has been achieved, but the men with the white coats would take me to the funny farm so I am expressing my feelings towards the device on this forum instead. sorry for the long winded post I just wanted to express how much I like this setup considering the money it cost etc.![]()
I agree, RDA's are perfect for me too,now but a mech mod and a couple of large batteries and you have it all.
Bought a Vamo v5 kit yesterday as an upgrade from my ego-c's. Hopefully I've made a good choice, I bought the Aerotank to go with it. Looking forward to it all arriving and getting set up![]()
Just back from asda, picked up some little angels cotton pleat, by god this stuff is damn thick, going to take a while to work out how much i need, so used to cotton balls - but 2 packs for 2.50 enough to last me till i die i reckon if it tastes better than the wilko's stuff.
I'm wondering what sort of taste you're describing with the Wilko's organic wool. I boil mine three times for 10 minutes in filtered water, changing water in between. How necessary that is, i don't know but i like to err on the side of cautionThat cotton wool is organic but it has been bleached (using non-chlorinated bleach).
There's no discernible taste whatsoever from the cotton that I can detect in protanks/drippers/kf type atties.
As an aside, I've learnt that one of the most important things when handling cotton wick is to make sure your hands are very clean and definitely not sweaty. Cotton doesn't like oils or dirt from the skin and picks them up very easily. Some people will put a tiny bit of juice on their fingers before handling wick which is also OK but things can get a touch slippery![]()
Cheers for the advice guys, so after watching numerous videos and reading lots of reviews I have decided to upgrade my eGo starter kit to an
iTaste MVP 2, this seems to get great reviews and the battery should last an age (http://myepack.co.uk/itaste-mvp-v2-0.html)
and a Kanger Aerotank (http://myepack.co.uk/aerotank.html) the reason I went for this now is that you can use the air flow control ring on other devices such as the protanks which maybe useful I guess.
Hopefully this will be a good upgrade there is so much out there I didn't really know what to get but these 2 kept popping up in recommendations so fingers crossed.
