- 11 Sep 2009
- France, Alsace
I think you've misunderstood sous vide somewhat
But you must already know the answer - you can't have picked a figure of an hour out of thin air without having done at least a little research into the subject.I was just thinking out loud and was hoping someone telling me I was wrong and it only took like 20 minutes or something.
In theory, everything should 'taste nice' with sous vide cooking as you're keeping all the flavours locked-in the bag with the food, meaning less of it escapes.I am trying to think of more things that tastes nice with this kind of cooking method.
Why is chicken/poultry out? Cooking chicken in the sous vide makes for amazing food. Or do you just not eat chicken?
Egg whites harder than your yolks? That's exactly what you'd get with sousvide eggs (and non-sousvide eggs tbh).
There are tons of options. Vegetables are a bit more hassle (and as such I've note experimented with them much) but options for meat are pretty much endless. Although it may take longer to cook the food you don't need to baby sit it and it often doesn't matter if you cook for too long so the potential effort/hassle savings are huge.
You don't "half-cook" everything. You cook the food to the exact point that you want it to be cooked to and no further.
It would have made more sense if you'd asked 'why does it take an hour' or 'what does an hour do to the egg' instead of a question that's only going to elicit a somewhat closed response.
Anyway, the answer to your question is - it will, but is does also depend on what your definition of 'cook' is.
The longer answer to the question I think you meant to ask, is that you can set an egg at temperatures above 60° by using cooking times of 40-minutes or greater, but you can achieve hugely differing results by varying the temperature and the time you cook the egg for.
The reason for that is down to the differing types of proteins within the egg and the effect that heat has on them - tight whites (the white that clings to the yolk) start to set first but only firm up at higher temperatures, loose whites (the watery, outer white) remain so until they reach a high temperature and yolks start to set at middling temperatures and solidify as you reach the higher numbers.
But while these reactions occur within specific temperature ranges, the effects can be modulated by increasing the time the egg is held at a certain temperature - for example, an egg cooked at 63° for 45-minutes will have a completely different yolk texture to one that's been cooked at the same temperature for double the time. Which one you prefer will depend on how textural you are when it comes to food.
In short, there's just as much room for experimentation with eggs as there is with any other food that's cooked in a water bath, if not more so.
Only you can answer that one.I knew it takes longer, but what it really comes down to is, was the wait worth it over a soft boil egg?
At a core temperature of 60° you're not going to kill yourself. With the meat being held at that temperature, sterilisation occurs within about 30-minutes.In terms of chicken and what not, I guess I like it hot and really want to make sure I don't kill myself cooking chicken at 60c.
Unless you've got a mouth lined with Asbestos, you're probably not putting meat in there which is truly hot - even something with a core temperature of 60° would probably be slightly uncomfortable and around 50° is roughly where you want to be for an edible temperature.I've seen Heston doing it in an oven, it looks intriguing I must admit. Think I like my meat hot, not lukewarm?
The 'weird side' of you doesn't really seem to grasp what sous vide cooking is actually about - you appear to be thinking along the lines in which the media portrays it.The weird side of me also thinks….this is way too easy or something. I guess I like a challenge to cook something, like cooking a steak perfectly pink in the middle with the outside just right. Or soft boil an egg just right. Or oven cook a chicken so it's moist yet with crunchy skin?
Common sense dictates a loss in temperature of 40% would increase cooking time by 650%?p.s. the hour thing was just a guess, if you boil water to 100c and turn it off and leave an egg in there for 8mins to get a soft boil egg. Cooking it in 60c with that thing would take longer, it didn't need research, it just common sense.
I'd love to see a "Sous vide tried and tested recipes" thread... with cooking times and hints and tips. Anyone care to start?![]()
I am just trying to get my head round it that's all.
I understand the science. I understand the search for something cooked to perfection (subjective)0, since this method is pretty idiot proof, it's like putting a ready meal inside a microwave, but instead of 8 mins, it's 8 hours or something. But no risk of anything blowing up, no risk of water evaporating away and hardly any chance of over cook. It almost sounds like a dream?
What I am trying to get my head round is, for example, is a steak cooked this way any better than say a steak over a BBQ?
Is an egg cooked this way nicer than a soft boil?
I am seriously curious about it and curious to try, I am not dissing it (it may sound like it) but the concept of boiling food in a bag draws memories of student days where you get a packet of pasta and sauce in a bag from Iceland…scarred for life.
Why pork belly. That needs heat to crisp up.
Yes when you can afford a decent sized steak then it's worth while. But you seen the meat I buy and I would still only have big enough steak one or two times a year.
I do want one, don't get me wrong. But I think people are over exaggerating their new toy and will soon tire off it. Other than a few tomes a year.
