@theonejat i personally don't use any texture packs so can't help you there.
The Vanilla server is set to hard mode so some tips would be always have food. If you starve you die.
Make a little build near spawn so you have a safe place to go out exploring from.
Check the first page for server commands.
Jump on and have fun.
@5punk3monk3y
How will the multiverse work on vanilla.
Will you have to connect separately to another world or will there be portals like going to the Nether and the End.
Also will these worlds be updated to the latest version and how will that affect the vanilla Overworld which is on 1.6.2 .
If the current Vanilla server is updated to the latest version will there be any
problems with Witch huts and Nether fortresses breaking.
Thanks for the hard work
@5punk3monk3y
