- 12 Sep 2012
- Surrey
No it went black.
Must be your monitor failing, better buy a new one
http://www.overclockers.co.uk/showproduct.php?prodid=MO-204-SA&groupid=17&catid=1895
No it went black.
Is that one 60hz???
If not then it's crap.
Is that one 60hz???
I will 100% be buying one of those 60hz 4k ones in June though.
Although by then I hope 32" ones will be cheaper
I have a pair of 780s running at 1095/1706 mhz.
Are they going to be enough?
I play mostly mmo's and other games with not-so-insane requirements![]()
Do you have the Bioshock infinite benchmark?
The game is not all that old but has fairly low requirements. Would be cool to see if it can get playable frames on higher settings on a single high end card.
I would appreciate it mostly![]()
Greg, what does it play like if you drop down to 1080 as I need a monitor but don't want to change my 7950s, someone else asked earlier but i think it got lost in all the other posts.
Apologies if you have answered![]()
TR is probably one of my most favourite games in the last few years. Could you do a single card bench with same settings you used on the sli one please![]()
I did a SLI bench on Bioshock and it was easy for the Titans. Max settings resulted in 34 min, 102 average and 350 Max. I posted it somewhere in the thread for you but lost it now
Any particular game you would like me to try and do you want me to start in 1080P and then compare of just run 1080P and comment?
BF4 would be good and maybe TR3 if you don't mind, ta muchly
Will do on BF4. Not sure what TR3 is?
