- 19 Feb 2007
- London
Jesus man. Those setups lol
Being single and having no obligations has it's rewards
It is a draw between my quad sli Titan/3930k setup and my quadfire 290X/4930k setup.
I don't think the extra GPUs help any with the problem I mentioned earlier and I think the result is the same using a single card or 4 way.
I am surprised you haven't put your order in yet Kaap. Civ 5 looks very very good
Seems that file is a bit too big...This is resized to 1080P
I wish you would stop uploading the pic`s Gregster , I keep getting more and more tempted.![]()
Just do it, mine is arriving this afternoon![]()
Same model? if not more pic and a comparison of build etc would be great
Either way enjoy your new screen!
Greg... Are you using your 4k monitor has a gaming monitor only? or are you using it for regular daily use too? Is the monitor compatible with google chrome and all other apps in windows?
Cheers
Yer I use it for everyday use as well but I tend to use the 1080P for apps and use the 4K for chrome.
Just curious, Greg, for those Black Flag screenies did you have the graphics all maxed out and were you using both Titans? If so, your fps seems pretty high compared to mine at 1440p with 2 780s - mine cannot manage Black Flag maxed out at 1440p, I get frame rates in the low 30s (unplayable for me).
Pretty sure it was fully maxed for the screenies but use 2*TXAA for gameing and get above 50fps average.
