Does life steal gear still exist at all? I've not seen any for absolutely ages. But seems odd that they would remove it completely? I had figured they had just made it less effective at endgame.
Gonna be praying to the loot gods for a Mask of Jeram later![]()
Lifesteal was removed because it's impossible to balance. At low damage, life steal is almost nothing so worthless. At high damage, you life steal a ton so are basically invincible.
Life on hit is much for simple to balance as it's effect will be constant.
