Folks what does mantle exactly do to help in games? Ive read up a little about it but Im non the wiser.
Mantle is the only Low level API currently in existence; its purpose is to reduce the CPU Bottleneck when compared with DirectX,
the result of that is you get much better performance, especially with the Minimum FPS and if you have a weaker CPU,
it’s not so much effective if you’re running an i7 3960K or 4960X, but then how many of us do?
More on Mantle here
You have got to build an absolutely huge civilization with loads of cities.
snip
Thanks humbug.
So you're saying Mantle is a software only driven improvement? Were looking at up to double performance according to the above! Is that true?
I have gone hammer and tong and owned the whole map bar the colonials and still runs like a dream (as seen from the iamge I posted at 4K).
The starswarm demo is a little misleading, as it also supports an option called "defered contexts" which when enabled on Nvidia machines gives a similar performance boost... The most recent nvidia drivers also give a good boost in this demo
So far mantle seems to give around a 5% boost in a lot of situations, and bigger when severely CPU limited, like low end cpu with high end gpu, or crossfire
Basically it is a little handy boost in 2 games with a few others announced, in all likelihood it will be deprecated by DX12
Still, Civ games have historically been cpu limited, so a good choice for Mantle marketing, will be interesting to see if they use command lists again (as they made a pair of 580's exceed a pair of 7970's in Civ5)
Some people have recorded some MASSIVE gains from the new Nvidia Driver.....
And lets not get into blanket statements when you're calling Mantle the only low level API in existence.
Is there any reason why you feel the need to but in on our debate here?
Are you being serious? It's an open forum.
Tell you what Humbug, I'll let you crack on with it.
Blanket statements. Your being very misleading, "defered contexts" does not give twice the performance, more like 20%
Nvidia's new driver only give a boost where the CPU is already very powerful, like a £450 3960K, does not help with CPUs that do not cost £450, thats why Nvidia only used the 3960K in their PR.
Nvidia's Drivers do not give anywhere near the same performance as mantle.
Blanket statement Humbug i'm afraid my old i7 960 sees a increase with the new driver Hardly a very powerful CPU by todays standards
I said Nvidia's Driver does see improvements "in Some Games" andybird said it gives similar performance to Mantle, its doesn't, not even close.
I would have thought it is hard to compare the two, since mantle supports only a few titles at the moment (if that), where as the Nvidia driver applies across the board to various games.
More than mantle at present, though. So, hard to compare the two surely?
