- 19 Feb 2007
- Sol
So after updating to the latest Corsair link *2.6.5214* the LED's on my unit would reset to an odd colour, So instead of red it would go a rose coloured pink.
So I decided to experiment a little
So far it seems it's only effecting people who update from 1.05 to 1.07 but units that ship with 1.07 appear to be unaffected.
Now this is a problem related to the firmware version 1.07 which is built into the latest release.
I have tested this on 3 different H100i's and all behave the same when updated from 1.05 to 1.07.
The fix is actually quite simple, Uninstall all link software and download the older *2.4.5110* link version which allows for manual firmware updates.
Once you have it downloaded and installed you want to download firmware version 1.05, Update/rollback the firmware to 1.05 from 1.07 and once done your LED's shouldn't change upon a cold boot anymore.
****Please download in Firefox or Chrome, Internet Explorer for some reason saves it as a .php file instead of a .zip/.rar file****
Corsair Link - 2.4.5110 - http://www.corsair.com/~/media/Corsair/download-files/drivers/link/Corsair-Link-Installer-RC-v2-4-5110.exe
H80i 1.05 - http://forum.corsair.com/v3/attachment.php?attachmentid=12219&d=1361765933
H100i 1.05 - http://forum.corsair.com/v3/attachment.php?attachmentid=12220&d=1361765948
Installation -
1. Uninstall Corsair Link.
2. Reboot.
3. Install Corsair Link Version 2.4.5110.
4. Flash your H80i/H100i to 1.05 *sierra2.bootloader has stopped working* will appear once the progress bar gets to 100% but don't worry this is normal.
5. Re-launch Corsair Link and set your desired color i.e Red, Green, Blue etc.....
6. Fully shut down your rig and wait about 60 seconds.
7. Boot up and after about 5 seconds the CPU block LED will change from white to your previously selected colour.
Hope this helps
Installation -
2. Reboot.
Hope this helps
