Glad you did. Mmmm, Kuro!
I'm starting to get an upgrade itch though! I need more than 60 inches now!
What's the view on TV height? I always thought it was best to mount with eye level at 1/3 the way up the screen, anyone care to confirm at all? I'll finally mount mine this wknd![]()
All of the equipment is behind the TV, under the stairs. All wires are hidden, including the rear surround cables which I hid inside the walls.
Hi everyone,
This is my first post. Accidentally stumbled across this forum when researching XBMC. Just thought I would post my current setup. This is my first time purchasing many of the components making up my home cinema system and as such I would consider it to be a fairly basic, entry level setup. All of the equipment is behind the TV, under the stairs. All wires are hidden, including the rear surround cables which I hid inside the walls.
Excuse the pic.
Samsung Series 6 rose 46" TV,
Yamaha RXV 675 AV,
Tannoy HTS 101 Speakers,
PS4,
MX Linux HTPC running XBMC,
Synology DS414 NAS
Did you use trunking through the wall? If not was it a hard job getting cables through the wall.
