r/cringe
Your Cringing and i don't know what to think, i think i'm going to sneak out of the room
r/cringe
Your Cringing and i don't know what to think, i think i'm going to sneak out of the room![]()
Like Herpes, its the gift that keeps on giving.
I'd say humbug is more Matts wingman
Anyway Matt is it worth me installing the new set? On RC atm and really cant be arsed to install these as im thinking if i stay on the Beta's theres less chance of any possible corruption when 14.5 Beta comes along.
Hey i'm just thinking ahead here![]()
Is the AMD Gaming Evolved app that installed itself with the new 14.4 drivers useful? Meaning does it do what its suppose to do well at all?
As long as the driver works fine, ignore it. Have you used a driver sweeper tool without first uninstalling the driver the normal way? Because ive had this happen before after doing that. The driver install fine, but it reports an error. The error us usual harmless and can just be ignored. The only solution i found was a system restore till before you used the driver sweeper or a OS reinstall. If you've not used such a tool, then no idea.
TL : DR
If you use a driver sweeper uninstall the driver first normally, restart into safe mode then use the sweeper.
In my experience the most reliable and safest sweeper tool to use is DDU. I wouldn't use any of the others and that includes AMD's own tool.
Ltmatt the savior for amd users
Good looking and knowledgeable. What's not to like?![]()
Matt! ah-ahh!
Savior of the Universe!
Matt! ah-ahh!
He'll save everyone of us!
Matt! ah-ahh!
He's a miracle!
Matt! ah-ahh!
King of the impossible!
